Button oiler
Steve Ruddy
02-09-2008 09:46:40
I'm looking for a fitting to turn a grease gun into a button oiler for lubricating the HG's trac. I found a complete gun with lube but it is very expensive and out of my price range.
Steve Ruddy
02-12-2008 09:21:10
 Re: Button oiler in reply to Steve Ruddy, 02-09-2008 09:46:40
BUILDING A HIGH-PRESSURE OIL GUN FROM A
LEVER ACTION GREASE GUN
http://www.metalwebnews.com/howto/oilgun/gunconvert.html
550Darrin
02-09-2008 18:05:57
From the archives of www.cletrac.org:
buttonhead fittings from Brown Supply ([email protected])
Harbor Freight sells a pneumatic grease gun for about 20 bucks (flip the plunger around to slow leaking).
McMaster-Carr www.mcmaster.com has the adapters for about 35 bucks
Steve Ruddy
02-09-2008 10:13:06
Landis is very helpful and generally has fair prices and good service however the oiler and or adapter I'm seeking is out of my price range.
Steve Ruddy
02-09-2008 12:16:02
 Re: Button oiler in reply to Steve Ruddy, 02-09-2008 10:13:06
It looks like Napa may have a Button Head Grease coupling. It is a Balken part # 7151152 This is apparently the standard size of 7/16" they also make a giant size at 7/8". I'll let you know if it works.
J Schwiebert
02-09-2008 16:56:55
 Re: Button oiler in reply to Steve Ruddy, 02-09-2008 12:16:02
What are you going to use to lubricate the rollers and idlers? Remember those operators manuals were written 40-50 years ago and lubricants have greatly changed !. I also sent you an e-mail How much winter use? Are you in the midwest(corn country)? Just asking and looking for points of view. J.
Steve Ruddy
02-09-2008 19:21:45
 Re: Button oiler in reply to J Schwiebert, 02-09-2008 16:56:55
I'm going to lubricate the track wheel bearings, track frame support bushings, and main spring bushings. Manual calls for SAE 60 above 70 degrees. Landis recomends I not use grease as it will not flow to all areas needed and say'e to use 90w gear oil.
Super 55
02-09-2008 09:58:58
Zimmmerman's has them, but I don't know how much they cost. The link for the price wasn't working on my browser, maybe you will have better luck.
