Oliver 88 Axle U-Clamp
Bill Johnson
02-08-2008 14:33:07
Greetings,
I"m needing a U-clamp for the rear axle hub for a 1950 Oliver 88. It"s the stock hub with the cast iron wheel center bolted to it. I"ve stripped one of mine and am looking for a replacement.
Thanks!
770
02-09-2008 07:08:52
 Re: Oliver 88 Axle U-Clamp in reply to Bill Johnson, 02-08-2008 14:33:07
I had some bent at a spring shop a couple years ago for my 770. They charged me $9. a piece (with nuts...)
Bill Johnson
02-08-2008 15:12:58
Larry Harsen had a good used one for a reasonable price. Thanks so much for your responses!
Ed Hodge
02-08-2008 15:05:51
go to a shop that make leaf springs thay can make up a set of 6 for about 50.00 out the door just bring one of your old one with you for a mach
old
02-08-2008 14:59:21
A good machine shop could make you one and would probably be easier then trying to find a good used one.
