Oliver 550 Gas, Need Info Please
LloydArms
02-06-2008 15:44:49
Do all the front end loaders on the 550s require a seperate hydraulic pump? Can the pump for the 3 pt hitch be tapped and used? Also I have a spare 550 transmission in pretty decent shape for sale. I don't know what its worth but all the gears and bearings look great. I purchased it for the pto assembly.
Chris Van
03-10-2008 12:13:19
 Re: Oliver 550 Gas, Need Info Please in reply to LloydArms, 02-06-2008 15:44:49
third party image
This is my loader set-up, although I only have upward (one-way) lift on the loader and nothing on the bucket (trip). The rear hoses are for a log splitter.
LloydArms
02-09-2008 18:30:39
I also have some 550 diesel engine parts such as block, cyl head for sale.
LloydArms
02-07-2008 11:02:02
 Re: Oliver 550 Gas, Need Info Please in reply to oliverhick, 02-06-2008 15:44:49
PJP, What email address should I email you at? I couldn't locate your profile on here. Shows you as a guest.
LloydArms
02-07-2008 10:58:45
Yes it has the remote valves.
J Schwiebert
02-07-2008 17:25:48
 Re: Oliver 550 Gas, Need Info Please in reply to LloydArms, 02-07-2008 10:58:45
Your remote valve will supply your hydraulic power for the loader.
pjp
02-07-2008 10:56:01
Might be interested in the transmission. Where are you located. e-mail me your phone number and I can give you a call. thanks
LloydArms
02-07-2008 10:06:27
 Re: Oliver 550 Gas, Need Info Please in reply to Merlin in Rushford, 02-06-2008 15:44:49
How much weight are you normally lifting? Also how/where did you tap into the 3pt hitch pump?
Thanks :D
J Schwiebert
02-07-2008 10:44:45
 Re: Oliver 550 Gas, Need Info Please in reply to LloydArms, 02-07-2008 10:06:27
Do you have a remote valve for a training cylinder. Remember lifting abality is going to be proportional to the size of the loaders lift cylinders. More questions? J
J Schwiebert
02-07-2008 10:45:36
 Re: Oliver 550 Gas, Need Info Please in reply to J Schwiebert, 02-07-2008 10:44:45
That should have been trailing (remote) cylinder. J.
SW3
02-07-2008 06:43:24
I have an Allied 300 loader on mine. It works fine running on the tractor"s hyd. pump. Main loader cylinders are a slow as J. commented, but the smaller bucket cylinders are plenty fast.
Good Luck.
J Schwiebert
02-06-2008 17:49:57
The 550 pump can be used, however it does not set the world on fire as far as GPM's go. So if you use it tie the handle back and maybe even get off and streach so to speak while the loader goes up. Get the idea. Determine what size cylinder you have (bore & stroke) what speed you want to run theengine and the nhow many seconds you want it to take to completely extend the lift cylinders. Then we can calculate what GPM pump you need. Questions? J.
