hg fuel
T Rapp
02-01-2008 17:50:24
When it is warm outside around 75 and up my hg 31 misses a little and if you shut it off you have to wait about 30min to restart it. I heard you could run kerosane and it might help because they were made to run on lower octane fuel. question any problems with running kerosane.
J Schwiebert
02-01-2008 18:08:38
 Re: hg fuel in reply to T Rapp, 02-01-2008 17:50:24
Well first of all one that runs on Kerosene has a small tank for gas which is used to start it and you also run it on gas for say 5 minutes before you shut it off. They also have different compression ratio heads. First think I would check is your spark. Is it good and blue capable of jumping a 3/8 inch gap? Also remember if you still have a mag the 2 plugs that fire on reverse polarity will foul out first. Just the law of physics. J.
t rapp
02-02-2008 13:54:35
 Re: hg fuel in reply to J Schwiebert, 02-01-2008 18:08:38
I just had the mag rebuilt. The only reason I asked is because in 1950"s they didn"t have as high octane of fuel as we do today and the carbs weren"t made for todays gas because it vaporizes easier then lower octane gas.
