Starting a Super 77 Diesel
Bob
02-05-2000 18:04:03
I just bought a super 77 today that runs on diesel. I was wondering if these tractors are hard to start in cold weather normally? When I say cold weather I mean Texas cold weather, 40 to 50 degrees. This morning my dad and I had to pull start it, but after it ran a while and got warm we could start it with the starter. The tractors runs on a 12 volt system.
highboyford
02-05-2000 20:44:56
 Re: Starting a Super 77 Diesel in reply to Bob, 02-05-2000 18:04:03
This tractor uses a preignition chamber to start.it is called the lanova system,anyway you have what is called energy cells in the head and they can get clogged or plugged up with carbon which will make starting a little more difficult.You need to make a puller to get them out thou they tend to stick pretty good.Good batterys do help and maybe the pre heater too but none of mine work I use starting fluid,or park on a hill.But here in Wi 50 would be a hot day right now.Also in mop if the tractor needs a rebuild it would have less compresion which therefor would make it start easier when it is cold compared to a engine that is in shape.
John Mann
02-05-2000 18:41:22
I have an 880 D. I overhauled the engine and made sure the preheater was working. I started it the other day after setting since the first of Sept. Temperature was about 27. I live in central Ky. Key to these in my opinion, have a good battery as much as factory or more. I have two 750 cca on mine. One powers the preheater one to start.I believe mine would start as cold as 0. Also refer to operators manuel to procedure. I don't believe in either.If it needs this to start it probably needs an overhaul.
tim
02-05-2000 21:06:06
 Re: Re: Starting a Super 77 Diesel in reply to John Mann, 02-05-2000 18:41:22
good batteries bigger the better preheater or a plugin heater for the block is easiest on the engine if ac power is available. i am not an ether fan either. good luck
