Seat replacement on a '55 series
RBTXS
01-28-2008 21:21:34
I plan to replace the seat on my 1955. Has anyone out there ever changed the plastic balls and stuff on the seat base? How can you tell if they are worn too much to need replacing? Any help would be appreciated.
Nusbaum Farms
01-29-2008 10:15:53
 Re: Seat replacement on a '55 series in reply to RBTXS, 01-28-2008 21:21:34
I assume you're talking about the plactic rollers, if so, I've never seen any that really need to be replaced due to being worn out. They don't normally see a lot of use, only when adjusting the seating position, and most people set the seat where they like it and then very seldom ever move it again. They are a simple change out though if you really need to. And they should have a little spring washer between the back side of the roller and the seat base. If you have a lot of side to side movement and your seat adjustment latch won't hold, you may need to put a washer or two between the roller and the base to tighten it up. Trial & error until you're happy. I also put a little silicone or graphite lube on the peg, roller and track and call it good.
Hope this helps.
Scott
