Hyfraulic Fluid ???????
tculp
01-26-2008 20:30:53
Oliver 1450 manual says use Type A Transmission Fluid. We can not find any. Does anyone know an equivilent.
Ed Hodge
01-27-2008 14:37:23
 Re: Hyfraulic Fluid ??????? in reply to tculp, 01-26-2008 20:30:53
type A is ford trans fuild back in the 70's you can still get it napa sells it dex 3 will trash the pump
J Schwiebert
01-27-2008 15:16:25
 Re: Hyfraulic Fluid ??????? in reply to Ed Hodge, 01-27-2008 14:37:23
Ed: You are dealing with a Fiat hydraulic system here. Not an Oliver> Like day and night difference.
J Schwiebert
01-27-2008 06:19:08
Make sure you remove the strainer(filter) in the unit and make sure it is good and clean!. Loosen the suction line at the pump so that oil gets to the pump before you start it. Make sure it is tight so you do not have a suction leak. Loosen the high pressure line so the pump will bleed any air in the pump. Like Mr. Grant said if you park the tractor on an incline and in your part of the state that should not be a big problem, (here I would need to put the front end down in a road ditch) so you get it bleed. Gear pumps do not pull much vacuum. Oh. Stay with the transmission fluid especially this time of year. More questions? J.
Don-Wi
01-26-2008 20:51:41
The modern equivilant is the Dexron/Mercon transmission fluid, but many guys substitute regular hydraulic oil in any situation that calls for type A fluid.
Donovan from Wisconsin
old
01-26-2008 20:51:31
Dexron 3 now days does it all
