Need an 1850 PTO shaft clutch
Kruse
01-26-2008 15:21:11
Pulling the engine in my brother"s 1850 diesel for an overhaul. Took the pto shaft out (the one that sits in the back of the crankshaft) and the grooves are so worn that we are surprised it didn"t shear off. Crankshaft spleens look good. Looking for a new one from some place other than AGCO. Any good, cheap sources? (I know you probably can"t use good and cheap in the same sentence here)
Also need clutch, and pressure plate. I have a good source, but am always open to suggestions. Anybody here have some recommendations? TIA.
rrlund
01-27-2008 09:09:26
 Re: Need an 1850 PTO shaft clutch in reply to Kruse, 01-26-2008 15:21:11
Mud and I both got them from agpartsfirst.com lately. Less than $200.
CRUSADER
01-26-2008 18:39:56
I'm not an Oliver mechanic, actually my experience with them is limited. But if I remember correctly the shaft from an 1855 will fit/work on an 1850.
Jim
