Oliver 550 - Trans and Diff Oil
MapleStone
01-23-2008 08:38:07
I've finally got my manuals and I was reading them as to my 3 pth problem, when I noticed that they recommend 10w-30 in the gear case/transmission along with "additive". You guys have previously suggested using 80W-90. Is this in leu of the additive? Why so heavy of oil?
SW3
01-23-2008 12:22:55
 Re: Oliver 550 - Trans and Diff Oil in reply to MapleStone, 01-23-2008 08:38:07
Any "addatives" they list are no longer available anyway.
Old Ford Mechanic
01-23-2008 09:53:14
Yes,Super 55 has given exellent advice.
Super 55 in Indiana
01-23-2008 09:21:00
10w30 can be used year round in the hydraulics only. The filler behind and to the right of the seat is the lift fill/check. The trans should have at least 80w90 in it. The trans fill is the aluminium plug behind the dash. 10w30 in the trans would leak out through the PTO seals in short order. As a side note, my original owners manual for my S55 states 140 weight can be used in the trans in the summer, so I split the difference and run 85w140 year round in my S55 trans. It seems to do OK, very little PTO seal leakage.
MapleStone
01-23-2008 12:31:51
 Re: Oliver 550 - Trans and Diff Oil in reply to Super 55 in Indiana, 01-23-2008 09:21:00
OK,
I'll trust you guys. I never thought about the seals.
I was surprised that the operator's manual mentioned 10W30. Now the manual is for a newer 550 with the checkerboard grill, I don't know if that makes a difference.
I'll stick with the 80W-90.
1755
01-23-2008 14:49:12
 Re: Oliver 550 - Trans and Diff Oil in reply to MapleStone, 01-23-2008 12:31:51
I just want to make shur you knew that the hydrolics and the trans/rear end are two seperat compartments my 550 book said to use 80/90 in the trans/rear end
MapleStone
01-24-2008 05:39:57
 Re: Oliver 550 - Trans and Diff Oil in reply to 1755, 01-23-2008 14:49:12
Yep. I know all too well that they are different. And I'll double check the manual but I'm sure it says 10W30 for the rear end and the hydraulics.
