Just a little input. Your procedure is good until you say to turn the engine over until the valve is all the way open. This is a common misconception but if the valves are going to make contact with the piston, they will do it when the valves are overlapping. This is when both valves are open just a little at the same time. When the valve is all the way open, the piston will be almost half way down in the bore. There is no chance of the valve hitting at that point. On my diesel pulling tractor, the bottom of the head is flat and I don't run any head gasket so the head is setting right on the block. My pistons come within .040" of the head. My valves open .640" but my valve reliefs machined in the piston are only .250 deep. What I am trying to show you is that if the valves were going to hit the piston when they were all the way open, they would but they never have. The proper way to check the valve clearance would be to put some clay on top of the piston and put the head on and install the push rods and rockers and set the valve lash on the cylinder you are checking. Then turn the engine over by hand two full turns. Now take off the head and check the thickness of the clay. Most racing engines shoot for atleast .080" clearance. Just remember that if you change your cam timing, these clearances will also change.
