OLIVER 550, GAS
DCHAF
01-18-2008 12:50:17
CAN ANYONE TELL ME WHAT TYPE OR GRADE OIL IS USED IN THE TRANSMISSION OF MY 550 GAS TRACTOR?
THANKS.
550Darrin
01-20-2008 22:53:51
 Re: OLIVER 550, GAS in reply to DCHAF, 01-18-2008 12:50:17
Glad to be of help. Now I have to help out another 199 people to pay back all of the help I've gotten from this forum.
550Darrin
01-18-2008 13:11:32
80-90W - 5 gals. Pour it in the large winged plug between your knees as you would sit on the tractor.
Check the level at the small pipe plug just up and to the right of the pto shaft.
There are three drain plugs for the transax along the bottom of the tractor. Pull all three to drain properly. You may want to put in 3-5 gallons of diesel and take it for a slow drive around the yard to clean out the transax a bit before you pour in your nice new 80-90W.
good luck.
DCHAF
01-20-2008 06:28:22
 Re: OLIVER 550, GAS in reply to 550Darrin, 01-18-2008 13:11:32
DARRIN, MANY THANKS FOR THE REPLY AND INFO. I WS NOT AWARE OF THE 3 DRAIN PLUGS. YOU HELLPED ME A LOT. THANKS AGAIN. DCHAF
