Oliver 62 and 50 Balers
MCL
01-18-2008 08:34:14
Do the 50 and 62 balers have any parts in common? I know the 62 has the roto-flow feed while the 50 had the auger. They are both twine balers. I also know the 50 is older. There was a model 60 in there somewhere too. Thanks.
Mike (WA)
01-19-2008 08:56:16
 Re: Oliver 62 and 50 Balers in reply to MCL, 01-18-2008 08:34:14
I'm sure no expert, but nobody else has jumped in- the 50 and 62 are different sizes. There was a 50, then later the 520. Next size up was the 60, then later the 62, then 620. Balers within a series are the same size, but the higher numbers denote a later model. Lots of parts interchange between early and late models within a series, but not so much between the different series (pickup completely different between the 50 and 60 series, for instance). Knotters are probably the same, but you'd have to look to make sure, unless somebody smarter comes on here who actually knows.
