broken pto?
kelvin page
01-16-2008 17:00:04
i have a super 55 and the pto will not go out of gear. i was mowing with it and it was like a pin or something broke in it because i had to cut the tractor off and disconnect the mower so i could crank the tractor back. i was wondering if anyone knew how i could go about fixing this, i found a open place under the tractor but dont know if i can get in there to replace the pin if it is a pin that has broken. any info. would greatly be appreciated! please e-mail back thanks
Super 55
01-16-2008 22:33:00
 Re: broken pto? in reply to kelvin page, 01-16-2008 17:00:04
That is the cover for the adjusting the clutch. I would start there. Look to see if you lost the set screw that holds the clutch plates on the shaft. Other than that you will have to split the tractor. Come back and let us know what you find.
