550 Carb #
dep
01-14-2008 20:16:28
I need to get a kit for the carb on my 550, but I noticed that it is missing the I.D. tag. Looks like there were a few Marvel Scheblers listed for that application. Can anyone tell me what the MS number should be? My I&T manual that covers the fleetlines has a table that list the serial # breaks for each different carburetor. Maybe the 550 manual lists the carb #'s also?
Thanks
Ritch
01-16-2008 18:39:16
 Re: 550 Carb # in reply to dep, 01-14-2008 20:16:28
Mines a TSX 811 Late model 1973
Farmritch
eeeeeeeeeeeeeee
01-15-2008 13:52:14
the early one Is a tsx-603
the late one is a tsx-118
Chris Van der Vyver
01-15-2008 07:12:40
Yours is a 1958. They used TSX603 until serial number 72831.
dep
01-15-2008 13:11:25
 Re: 550 Carb # in reply to Chris Van der Vyver, 01-15-2008 07:12:40
Thanks Chris!
J Schwiebert
01-15-2008 03:12:40
First of all the big difference is venturi size. The early 144 cubic inch engines have a smaller venturri than the larger 155 cubic inch engines. How about a serial number.
dep
01-15-2008 05:31:22
 Re: 550 Carb # in reply to J Schwiebert, 01-15-2008 03:12:40
John, looks like the serial # is 68100.
Thanks.
CENTAUR
01-14-2008 20:59:12
You may find that one main gasket fits all the differant numbers is all you need. .Leave the brass fittings where they are.Just blow it out with lots of high pressure and VOLUME.Also it would clean the best the wetter the air.If the needle is not rusted use it again.Look at the float setting before you remve it so you will know to leave it the way you found it.CENTAUR
