HG-0C3
Tim
02-03-2000 08:21:41
What is the difference between a HG and a 0C3 crawler. I would like to find a small crawler like this with a bad engine or no engine at all. Any leads? Thanks
RonMC
02-05-2000 19:30:13
 Re: HG-0C3 in reply to Tim, 02-03-2000 08:21:41
Found one - have a look, RonMC Note - $CDN is 2/3 $US
MAJ
02-05-2000 20:06:17
 Re: Re: HG-0C3 in reply to RonMC, 02-05-2000 19:30:13
that ain't an OC3 its either an OC-4 or OC-46.
wish I had $5,800 about now!
MAJ
Gary Hearn
02-05-2000 15:10:25
Actually, the HG and OC-3 both used Hercules engines. However, they were fitted with manifolds embossed with the Oliver name. The easiest way to identify an OC-3 is by the dish style front rollers, the HG used an open spoke type that ran inside the chain, not outside as on the OC-3.
Kelvin
02-04-2000 20:18:40
There's not a lot of difference between the HG and the OC3. The HG's are generally older and have Hercules engines. Where most OC3's have Oliver motors. Here again most parts are interchangable. They're out there. They were a popular little crawler that are greared a little high.
RonMC
02-03-2000 18:05:12
Hi - Just found this crawler on a Canadian Web site (farmach.com) - canadian dollar is 2/3 US, just to help with the conversion - think this tractor is in Alberta (get out the map) - Note, this will take about 30 seconds to load.
