Attn: Jim Wickham...
Merlin in Rushf
01-07-2008 19:37:12
...hello, again! Yes...you need to use an SAE #3 flywheel housing. The one to use has three mounting pads on each side of the housing. I have a Cummins option data book with the correct numbers...but it is up at my Dad's place. The White Americans, as well as the 100, 120, 140, 125 and 145 all used the same flywheel housing. The flywheel on the White American is a 125/145 flywheel with the outer "pot"-type ring machined off. I would recommend just using the standard 125/145 flywheel, and a 14" clutch. You will have to install the larger-spline input shaft in your Over/Under unit to do this, but a good used shaft can be found easily. Lots of other details, but this should be a start. You will have to remove the lower mounting pad on the flywheel housing on each side, or else it will not drop into the "tub" frame deeply enough. Best wishes for a successful outcome!
Merlin
Jim Wickham
01-09-2008 04:03:13
 Re: Attn: Jim Wickham... in reply to Merlin in Rushford, 01-07-2008 19:37:12
Thank you for the post. I tried to email you from the last post but I'm not sure that works from this forum for me. My email is [email protected] if you would like to send me some more specifics....
Thanks, Jim
