Need Distance Measuring Equip
Dave Bowers
09-19-1998 08:32:09
I need a distance measuring device for a pulling sled. Thank you for your consideration.
Dave Bowers [email protected]
1 602 843 2812 fax 843 2861
Os Blacker from Down Under
09-19-1998 19:18:58
 Re: Need Distance Measuring Equip in reply to Dave Bowers , 09-19-1998 08:32:09
: I need a distance measuring device for a pulling sled. Thank you for your consideration.
: Dave Bowers [email protected]
: 1 602 843 2812 fax 843 2861
Hi Dave. Would it be possible for you to use a small electronic Mountain Bike accessory which I have adapted for use on my enduro motorcycle. It uses a small magnet glued to a wheel. The circumference of the wheel is then programmed into the speedo which is very accurate and gives all sorts of information such as top speed, distance travelled this trip, total distance travelled, time, average speed etc. If you want more info I can give it to you.
