oliver 77 help
jeffbrown
01-05-2008 11:40:33
Hello everyone! Need help on my first tractor repair,have been reading your posts for months.After redoing the head and replacing all of the leaking fuel lines and having all injectors cleaner and reset I have started it and let it run for 30 minutes to get everthing warm.Now a small bit of blow-by oil smoke is coming from breather tube on valve cover,Is this o.k.? Also please tell me where to find how to replace the seal on the governor shaft and any problems this thing leaking bad causes? Thanks for any info, Jeff
J Schwiebert
01-05-2008 11:50:26
 Re: oliver 77 help in reply to jeffbrown, 01-05-2008 11:40:33
Did you retorque the head while it was warmed up? Did you put either new rings or new sleeves and pistons in? If so and you have a chrome top ring you need to get a load on the tractor to hel-p seat the rings. That may be the cause of your blow by. On the governor. You will need to get a kit for a PSB pump from an AMBAC parts supplier. The shaft is NLA, you will need to work on yours. I had an article on how to do that a while back in the HPOCA magazine.
jeffbrown
01-05-2008 12:02:52
 Re: oliver 77 help in reply to J Schwiebert, 01-05-2008 11:50:26
No block work, everything was very nice. problem was tractor sat outside for a few months without hood and as all I have seen the nuts on valve cover were too tight and rain water leaks around stud into valves and 3 of them were sticking from condensation.Will retorque now. Thanks for the info on seal.So there is more of a problem than just fuel leaking, all I have is a I&T book and you know they not very good. Any good places to veiw a breakdown of those parts? Thanks again,Jeff Also what can you tell me about serial# 21 986-702? Thanks again
jeffbrown
01-05-2008 12:35:42
 Re: super 77 screw-up! in reply to jeffbrown, 01-05-2008 12:02:52
Well you better hold your gut! as i removed the valve cover to retorque the bolts i seen my new smoke problem, i never tightened the rear exhaust rocker arm lock nut on the adjusters so it backed out and fell out and all that pressure was going into crankcase! I gotta stop tring to read everything and work on everything at the same time. LOL everybody!!!!! !!!!! !
jeffbrown
01-05-2008 12:41:56
 Re: super 77 article in reply to jeffbrown, 01-05-2008 12:35:42
J-I forgot to ask do you know what months that was in? I live in springport and chris has helped me out so i can get a back date from him. I'm "NEW" to the oliver thing but have gottin the bug! Thanks again for any info,Jeff
