Rollover plow
TractormanNC
01-05-2008 05:37:10
Yesterday went to look at a White 6342 5 bottom (convertable to 4) rollover plow. Appeared to be in good condition, price a little high. What can you guys tell me about this plow? Good, bad, anything I should check very carefully? I have pulled 4 bottom plows (not rollover) before so I know I have enough horsepower to pull it but what about all that extra weight hanging back there? Thanks for any advice.
Leonard
supersweetandseedless
01-06-2008 17:27:19
 Re: Rollover plow in reply to TractormanNC, 01-05-2008 05:37:10
A 4240 will have its hands full with 4 bottoms. If you are considering buying this plow, the most important thing to make sure of is to make sure the frame/beam is straight because if it is not straight it will not plow the same in both directions. The plow shares should all be setting flat on the ground.
carolinaoliver
01-06-2008 10:25:39
I have experience w/ 3 bottom rollover Ford which I assume was Oliver, on 4230 in Rowan County. In red clay was a good match. Would not pull a 4 bottom.
TractormanNC
01-05-2008 12:50:19
Thanks for the reply
I am planning to pull it with a J*** D**** 4240 (approx 110 PTO hp). I will probably need a full rack of weights on front.
Leonard
J Schwiebert
01-05-2008 18:44:23
 Re: Rollover plow in reply to TractormanNC, 01-05-2008 12:50:19
My cousin had one. Only one we sold behind a 4020. Yes they had to put some weight up front.
TractormanNC
01-06-2008 06:55:03
 Re: Rollover plow in reply to J Schwiebert, 01-05-2008 18:44:23
Thanks again. How well did the 4020 handle the weight?
Handsome Jim
02-04-2008 04:20:49
 Re: Rollover plow in reply to TractormanNC, 01-06-2008 06:55:03
ggod
J Schwiebert
01-05-2008 08:16:46
There was probably 10 of them around this aera. Weight is a key also the capacity of the 3 point. What do you intend to pull it with? An 1850 with a Cat 2 hitch has all it can handle to lift the plow if clods hang on the moleboards.
