415 Oliver pull type mower
Jon Bottum
12-31-2007 17:48:59
Hi- I found a 415 Oliver pull type mower that looks to be in good condition. Does anyone have any idea what it might be worth? Paint,decals & everything else appears to be good. Also looks like it's always been housed. Thanks in advance.Jon
Iowa770
12-31-2007 18:39:58
 Re: 415 Oliver pull type mower in reply to Jon Bottum, 12-31-2007 17:48:59
I've got one of these. I wouldn't pay over $200 for it. I paid less than this with about 50 percent sickle life left in it. I've used mine but without a crimper hooked up behind it tends to pull a little off to the side if you try and go too fast. If you don't have too much to cut it probably will work fine. The 415 seems to be more common than the belt driven models of the same era. The 415 was the pitman version of a line of mowers.
