Oliver 1850 Steering
Jerry Cox
12-31-2007 15:16:53
I have an 1850 with a wide front end. It has a saginaw powersteering hydromotor. The tractor has been sitting, mostly outside, for about 6 years. It will not turn to the right, and turns only part of the way to the left. Any suggestions? I have changed the filters, new oil and the hydromotor is getting oil. The unit is self bleeding. Once again, any suggestions?
Fern(Mi)
12-31-2007 17:57:56
 Re: Oliver 1850 Steering in reply to Jerry Cox, 12-31-2007 15:16:53
Jerry:
We had similar problem with an 1850 a summer or two back. If the three point and remotes are working, check your hydraulic priority valve. It�s on left side rock-shaft case, while sitting on seat. Open backside of priority valve clean and reassemble. A slug or accumulated dirt or crud may have gotten into it???? Worth a try. Worked for us. Check your parts book far all what is inside. I think there�s n two way extended stem with a machined valve surface on short side, the longer side fitted with spring. I�d be best to check your parts book. I�m not entirely sure. It�s an age thing and my story.
Fernan
