Urgently needed oliver 1850 parts
Os Blacker
09-18-1998 20:14:09
PLEASE HELP !
I need an Oliver 1850 Flywheel Ring Gear.
The engine is a Perkins 6354 however Perkins cannot supply the correct Ring Gear. Oliver obviously fitted their own Ring Gear to the Perkins engine.
Mike
09-18-1998 22:41:29
 Re: urgently needed oliver 1850 parts in reply to Os Blacker, 09-18-1998 20:14:09
: PLEASE HELP !
: I need an Oliver 1850 Flywheel Ring Gear.
: The engine is a Perkins 6354 however Perkins cannot supply the correct Ring Gear. Oliver obviously fitted their own Ring Gear to the Perkins engine.
Hey Os call Lind Implement out of Colfax Iowa at 1800 533 0661. They are a White and Oliver salvage yard and have about 100 acres of nothing but Olivers and Whites being parted out. Have your tractor serial number ready just in case. Good Luck
Os Blacker. Queensland Australia
09-19-1998 01:25:08
 Re: Re: urgently needed oliver 1850 parts in reply to Mike, 09-18-1998 22:41:29
: : PLEASE HELP !
: : I need an Oliver 1850 Flywheel Ring Gear.
: : The engine is a Perkins 6354 however Perkins cannot supply the correct Ring Gear. Oliver obviously fitted their own Ring Gear to the Perkins engine.
: Hey Os call Lind Implement out of Colfax Iowa at 1800 533 0661. They are a White and Oliver salvage yard and have about 100 acres of nothing but Olivers and Whites being parted out. Have your tractor serial number ready just in case. Good Luck
Many thanks Mike for your advice. I will give them a call.
Mike
09-19-1998 11:38:34
 Re: Re: Re: urgently needed oliver 1850 parts in reply to Os Blacker. Queensland Australia, 09-19-1998 01:25:08
: : : : PLEASE HELP !
: : : I need an Oliver 1850 Flywheel Ring Gear.
: : : The engine is a Perkins 6354 however Perkins cannot supply the correct Ring Gear. Oliver obviously fitted their own Ring Gear to the Perkins engine.
: : Hey Os call Lind Implement out of Colfax Iowa at 1800 533 0661. They are a White and Oliver salvage yard and have about 100 acres of nothing but Olivers and Whites being parted out. Have your tractor serial number ready just in case. Good Luck
: Many thanks Mike for your advice. I will give them a call.
Hey Os I did not know it but Lind Implement no longer uses the 800 phone number and they went back to their (515) 674-3577 phone number I'm sorry about that I hope this will be better for you. I did try this phone number myself so I know that it is current, I just called them a couple of minutes ago to comfirm it myself. Again I'm sorry about the wrong phone number.
Os from down under
09-19-1998 19:09:05
 Re: Re: Re: Re: urgently needed oliver 1850 parts in reply to Mike, 09-19-1998 11:38:34
: : : : : : PLEASE HELP !
: : : : I need an Oliver 1850 Flywheel Ring Gear.
: : : : The engine is a Perkins 6354 however Perkins cannot supply the correct Ring Gear. Oliver obviously fitted their own Ring Gear to the Perkins engine.
: : : Hey Os call Lind Implement out of Colfax Iowa at 1800 533 0661. They are a White and Oliver salvage yard and have about 100 acres of nothing but Olivers and Whites being parted out. Have your tractor serial number ready just in case. Good Luck
: : Many thanks Mike for your advice. I will give them a call.
: Hey Os I did not know it but Lind Implement no longer uses the 800 phone number and they went back to their (515) 674-3577 phone number I'm sorry about that I hope this will be better for you. I did try this phone number myself so I know that it is current, I just called them a couple of minutes ago to comfirm it myself. Again I'm sorry about the wrong phone number.
Mike. Many thanks for the phone call this morning. I called Lind and they will get back to me on Monday . Sounds promising thanks again.
