Brush Mower for Cockshutt
C35
12-28-2007 15:54:09
Whats the best setup for brush mower on a cockshutt?
I have a couple old feilds growing in and would like to keep them cleared next season when the 35 is done.
tag alder and such a bout an inch so far growing into field and lots of old growth hay. I'm not looking to hay this just keep the feild
c35
12-31-2007 04:18:46
 Re: Brush Mower for Cockshutt in reply to C35, 12-28-2007 15:54:09
Any chance I could get a picture of your hydraulic cylinder set up?
C35
12-29-2007 04:34:45
I have about 25 acres of same type old hayfeild. And no 3 point at least yet but do have the hydraulics so if I can find a junker with the parts I'd like to add that.
I'll start hunting for the Woods mower too
Thanks Peter
jakemb
12-29-2007 10:28:18
 Re: Brush Mower for Cockshutt in reply to C35, 12-29-2007 04:34:45
I put a hyd cyl. on this mower after one day of cutting,that way i can quickly lift it when a rock gets underneath,i've seen a number of these in the photo adds on this sight.i'm sure you have more hp than my a and it did a fine job.the first cut took some time but now it's going alot quicker.
jake
c35
01-01-2008 06:50:35
 Re: Brush Mower for Cockshutt in reply to jakemb, 12-29-2007 10:28:18
jakemb
12-28-2007 19:12:42
Not sure how big your fields are but our property we purchased had about 15 acres of old overgrowen pasture.I purchased a used pull behind woods mower and even with all the rock etc I managed to find under the grass it worked every well to keep it clean up.I ended up with a pull behind because at the time I only had my john deere a and ar with no three point or live pto and even with those it worked great.Now with my cockshutt with more power and live pto next year it should go a bit quicker.Hopefully get to the point where i can use the sickle mower.
Jake
