77 oil pressure
Bryce
12-26-2007 07:23:31
Can I tap the by pass port inside the front cover and drill a smaller hole in the plug to up my oil pressure?This is a new pulling engine and I would just like a little more pressure.Thanks for any help. Bryce
J Schwiebert
12-26-2007 19:37:51
 Re: 77 oil pressure in reply to Bryce, 12-26-2007 07:23:31
How much pressure do you have now? Which spring are you using? In simple terms when the 3 digit tractors came out the oil pressure was increased by using a different spring. That spring may give you an extra 10 psi. w2hat oil filter base are you using? Your turn. J.
Bryce
12-27-2007 06:06:47
 Re: 77 oil pressure in reply to J Schwiebert, 12-26-2007 19:37:51
10 as it sits,25 withit plugged and a 3/16 hole in the center of the plug,and the base is stock uses a fram c253.P.S stock 77 spring.
