3 pth/pto problem
steve
01-31-2000 13:38:39
the problem is i dont have one.....i have a 770 ind. with a ware hydro trencher hoe, minuteman style, is there any way to get a 3pth and rear pto to run equipment, ie. tiller, spitter, mower etc...., and where and at what cost might i find one?? thanks
paynes
02-06-2000 05:23:47
 Re: 3 pth/pto problem in reply to steve, 01-31-2000 13:38:39
Late 770 and 880 units came with a factory 3-point hitch. Be careful - there is a hydrahitch with a 2-point quick hitch adaptor (like used on the big oliver plows) but no top link mount - make sure you specify. I do not know if this will fit an industrial. The PTO unit should be easier - if your housing has a cover at the rear you can install one. Definitely suggest a parts manual and/or service manual, about $30-40 each, to guide you. Parts book has better look at what you need, service manual gives fair description of how to do it.
rodger
02-02-2000 05:00:16
In Lawrence, Ks, there is a dealer--Shuck Implement, who deals with a lot of Oliver stuff, and has a salvage of a lots of Olivers. I'd suggest you give him a call about what you need. He might even have it.
Good luck.
