Axle Trumpets are leaking.
Steve Warfle
03-20-2000 07:33:24
I knew things were going to good. My Zane Thang equipped 2N is starting and running strong. But now it's leaking from wher the axle trumbpets bolt up. I switched to the new hydraulic fluid, and I figure that contributed. Is it a big job to fix this?
I don't own a torch, hydraulic press, or a six foot breaker bar. But I'm handy, and have all kinds of jacks, and other tools.
Thanks
Steve
ZANE
03-20-2000 10:24:19
 Re: Axle Trumpets are leaking. in reply to Steve Warfle, 03-20-2000 07:33:24
Steve, is it leaking at the axle end or the big end where it bolts to the differential housing.
If it is leaking at the axle end I have a fix that I have used many times and never have had one leak.I posted it for the 8N NAA but is the same for the other tractors too.Including the TO and TE Fergusons.
If the hub is not extremely tight so that you have to have a puller to get it off I think you can replace the seal yourself. If the hub is tight that is a good sign you might get it to stop leaking.The problem with the 48 8N is that it does not have an inner seal like the 51 and 52 do. If the hub is loose on the axle and it can't be tightened because of the spline being worn too much to allow any more tightening then you will not be able to stop the leak the conventional way unless you replace the axle and hub. I hope that is not the case.
If the axle is worn too much to allow it to be tightened then you might consider my fix for the leak and leave the hub loose a few more years. To fix the leak my unconventional way you pull the axle away from the axle housing about 6 or 8 inches and wrap the axle for about 6 inches from the outer end of the axle that is exposed with teflon tape.Wipe all the oil from the housing and then take a caulking tube full of silicone glue and pump it into the void between the axle and the housing. Keep the hub as close to the housing as you can till you get the silicone pumped in.Use the whole tube and then replace the axle into the housing and replace the bolts etc. Let the silicone cure overnight and then you can go about using the tractor. Be sure that the oil in the rearend etc is not over full as this will contribute to the axle leaking.
If it is leaking at the differential it is not even necessary to make or buy a gasket. Just squeeze out a good bead of RTV silicone glue all the way around and bolt it up. If any of the old gasket is left on the housing and trumpet leave it on and use the RTV over it. That way you won't be loosing any of the shim effect of the gasket.
Steve Warfle
03-21-2000 05:33:38
 Re: Re: Axle Trumpets are leaking. in reply to ZANE, 03-20-2000 10:24:19
Zane....I printed your fix out for the archives. But my problem is simpler. The big gaskets at the Axle Trumpets are leaking. I snugged up the bolts, but it only slowed the leak. I don't want to overtorque them. When I rebuilt the brakes last year, I installed Sure Seals and everything else seemed in real good shape.
Can I just jack up the hub, and unbolt the trumpet, slide it out on a rolling jack, and then shoot some RTV in? Or does something hold the axles from sliding out?
Thanks
Steve
ZANE
03-21-2000 19:43:40
 Re: Re: Re: Axle Trumpets are leaking. in reply to Steve Warfle, 03-21-2000 05:33:38
If you have a chain hoist you can hang the axle housing and axle if it is balanced and be able to handle the axle and housing while still assembled. some times it is hard to get the spline to align but it can be done if it is where you can manipulate it fairly easily. I don't think you coule do it with a jack because of the balance point and trying to get it to stay on the jack. The wheel should be removed first or it will really be hard to handle.
tOTG
03-21-2000 05:45:41
Only those dozen bolts hold it together. It will roll away as you intend.
John.CO
Steve Warfle
03-21-2000 10:23:25
 Re: Re: Re: Re: Axle Trumpets are leaking. in reply to tOTG, 03-21-2000 05:45:41
That's what I was hoping for. She'll have to leak for a month or two. I'm too busy using her.
Thanks!
