Order Ford 9N Parts Online
9N Serial #
Gary
03-20-2000 05:21:45
I have a 9N that I've owned for approximately 7 years. I had originally thought that it was a 41' but upon checking the Ser. # recently I'm a bit confused now. Seems there's an extra digit. The number on the left side of the block is 9N218368. That doesn't correlate with the book. Anyone have an idea? It has verticle grille and three spoke steering wheel.
Gary
bg
03-20-2000 07:09:42
 Re: 9N Serial # in reply to Gary, 03-20-2000 05:21:45
Sounds like a '46 2N by the #. The 9N and 2N serial #'s both start with 9N******. 8N's start with 8N and stars before and after the # means steel sleeves. Diamonds means cast-iron sleeves. But you might find a steel-sleeve block that has been bored and fitted with cast-iron sleeves.
Since the blocks and many other parts are interchangeable. you could find a 9N or 2N with an 8N block or vice-versa. Casting numbers and production features can help narrow down mystery tractors.
