Order Ford 8N Parts Online
2N v/s8N Compression
Mason W.V.
03-14-2000 17:36:59
A quick question for you experts out there.. All the info. I read says that a 2N & an 8N have diffrent compression ratios. First I do know that cast Iron pistons & alum. pistons end up with different comp. ratios, but metallergy tells us that cast iron should be higher. Is there A difference in the heads? If so the compression chamber must be smaller on 8N.. Second changing my 2N over to .090 cast sleeves do I need to do any thing else besides bore out .040 sleeves & over bore to .090 sleeve recomended tolorence?
thanx in advance, Mike Mason
Fred
03-16-2000 14:52:24
 Re: 2N v/s8N Compression in reply to Mason W.V., 03-14-2000 17:36:59
This fellow is so far over my head with the metalurgy and all that I'm gonna call out for the resident expert to answer this one. HEEEEEYYYY
ZAAAANE!!!
