Order Ford 8N Parts Online
8N and King Kutter 72 inch mower
Brian 8N505142
11-30-1999 15:44:31
I'm planning on purchasing a King Kutter 72 inch finishing mower this spring, but I'm kinda worried about how close the caster wheels on the mower will be to the rear tires; Any of you guys out there with the KK mowers have problems with this? Or am I worrying about nothing? I just gotta say that I LOVE my 8N!!! Had to get that off my chest. Did some bush hogging yesterday, was kinda sad when I got done... I guess I'm hooked :-) Brian in S. IL
Dell (WA)
07-24-2008 13:01:43
 Re: 1950 8N Economizer Jet Hole Size - What is It? in reply to Gaspump, 07-24-2008 11:41:57
Gaspump..... .hummm? These hand written notes credit you as source. Maybe I NEED NEW GLASSES, eh? Main = 0.052" (#55), Idle = 0.0465" (#56), Econo = 0.037" (#63) At least I got the thread sizes and locations correct, huh?..... the embarrassed Dell (blush)
BTW.....My never been used A&I full carb kit (p/n; MSCK56) just mike'd with virgin wiredrills; yes, I do have and used a wiredrill template gage 8-32 main = #50 (0.070") 10-32 idle = #66 (0.033") 8-32 econo = #63 (0.037")
soundguy
07-24-2008 06:34:05
 Re: Won't Start in reply to drdarwin, 07-23-2008 18:41:28
Please be a little more specific. measure across battery posts.
From your message.. can I assume that when measuring across the posts, and you turnt he key on, that the bat drops to -0- volts?
soundguy
Jim WI
12-01-1999 10:29:38
 Re: 8N and King Kutter 72 inch mower in reply to Brian 8N505142, 11-30-1999 15:44:31
I have a 2N and a KK 72 inch mower. Never had any trouble with the guage wheels being too close to the tractor wheels -- they sit far enough back that I'm not concerned at all.
With my 2N, I mow in second gear. I've heard from a few folk with 8N's that they can mow in third gear with a 72 inch mower. (Maybe I need to upgrade my tractor?)
Part of what I mow is a blue grass / fescue mix. That mows real well, unless it's way longer than it should be.
The other part is what used to be pasture. It's got everything from june grass to alfalfa to weeds. That doesn't cut as evenly if it's just a little too long.
pete
12-01-1999 03:44:21
I have a 6 footer for my 2n and I just love it. I used to use a riding mower with a 4 foot cut and it took me 14 hours to cut 10 acres. It now takes me about 4 hrs. The king kutter is built very well and its well worth the money. I have three friends who were skeptical at first until they saw it work and they now have them also.
Gaspump
11-30-1999 16:42:05
I have had my King Kutter 72" finish mower for 5 years now and use it behind my 8N, 2N or 960. I have not had a problem with the wheels being too close on those tractors. Usually mow with my 2N which is pretty much original as in unrestored. It handles the 72" in second gear until my argentine bahia grass gets too tall then I must drop to first. This is extermely tough rapid growing grass, among the toughest to mow. Your tractor should do just fine! Go for it, King Kutter is a lot for the money.
JerryU
11-30-1999 16:31:01
I have a 5 footer KK and have never had any trouble. I use stabilizer bars and it tracks perfectly. The 8N might work better than the 9N that I have, but in heavy lawn grass, the 5 footer is about all I would want to go. I do see where plenty of other guys use a 6 footer, though.
JerryU
