2N casting numbers
erik
11-28-1999 18:24:11
Where are the casting numbers located on a 2N tractor? I want to know when mine was made, not just the year. Is there a casting number that tells you the date of manufacture that is readable without dismantleing the tractor? Thank you.
Jack
11-28-1999 22:21:46
 Re: 2N casting numbers in reply to erik, 11-28-1999 18:24:11
Look on the rear axle housings. The date of casting may be on the front side, upside down.
Jim(UT)
11-29-1999 09:00:53
 Re: Re: 2N casting numbers in reply to Jack, 11-28-1999 22:21:46
Those casting dates are the dates the axles were cast. You may find other casting marks on other pieces. Likely they will not all be the same date. As far as a date when the tractor rolled off the line as a completed unit, I don't know that you can pin that down with 100% accuracy. My 850 has axles that were cast 3 days apart. I figure they had to cool for at least another day or two before being installed. Plus they may have sat in a parts bin for a couple of days. Tractor probably rolled off the line a week later. jmho.
