Order Ford 8N Parts Online
8N lift problems........still
David 8N482352
11-28-1999 17:43:50
I went through my pump this summer and replaced relief valve, gaskets, etc. Also replaced piston rings to reduce leak down. Was never satisfied even after all of this. Lift just took too long to lift a heavy implement; and had to be idled way up to do it. Decided that my problem was flow volume related so I took the bolt out of the top of the touch control lever housing and pulled the lever up further than supposed to. Voila- 16 disk harrows picked up fast, and I mean fast. When I shut down motor they stayed up too. This is how I believe this is supposed to work. I referred to manual paragraph 101A and verified that the lift lever quadrant (4 bolt housing) was already maxed out. So, inside I go. I reset both springs as per the instructions. The smaller of the 2 required alot of adjust(about 1/4" to be in spec). Everything in here seems very loose, but it all appears to be there. Put it all back together and it works fair. Lifts my disks faster than it used to, but still not as fast as it did when I lifted the lever out of the housing. But, now with the small lever under the seat in the down position I have no lift at all. Nothing.
All of the lifting and lowering action used to occur in the upper 1/4 of the lever range; now it has shifted so that it is more spread out. I put my hand in the pump area and confirmed that the rod is now pushing the valve lever up next to the pump housing like it should. It was not achieving this before and now it is after I made the adjustments. So, why am I not moving my harrows up at the same speed as when I unrestrict the touch control lever? Have I adjusted improperly or is the lift not supposed to work rapidly. Also, the leakdown now is faster than when I lifted the lever out of the housing. This leads me to believe I have something worn. I know the lift is capable of lifting and holding up a heavy set of harrows as I have explained. Also, when pulling the harrows I bog down fairly easily. Governor recently rebuilt, as was engine. Carburetor set as per 8N website instructs. Still bogs under heavy load. Any ideas? Should my 8N pull a set of 16 disk harrows through sandy soil without laboring or am I expecting too much?
Thanks in advance for all of the help!
David Martin
Dave in Mo
11-28-1999 19:53:11
 Re: 8N lift problems........still in reply to David 8N482352, 11-28-1999 17:43:50
Dave, I'm assuming your disc is 2 sets of eight which would be rather narrow. Our 8N pulls my disc (2 sets of 12-about 7ft wide) in 3rd gear no problem. My cousin's 8N can't do it on the same field with the same implement-shows you about power variations due to timing, low compression etc.
ZANE
11-28-1999 19:16:26
Did you inspect the cam follower pin? it does make a world of difference in the operation of the position control linkage adjustment.
When you were in the lift you should have inspected the shaft from the draft sencing spring where it goes into the lift inside.They are sometimes bent from shock load such as hitting a stump or large rock. If it is bent you can't hardly get the draft control adjusted because you will not have enough room for the proper adjustment on the draft linkage.
You need to be using the draft control to keep the tractor from bogging down. This is the reason the Harry Ferguson invented the thing in the first place.If the lift will not lift the implement with the selector lever in the down postion (draft) you can still use the draft by moving the small lever down and adjusting the stop somewhat toward the top of the quadant and using the position control to do the lifting till you can go back in and set the linkage again.
Also be sure that you have all the slack out of the large draft sencing spring by tightening the yoke which is threaded till it is snug plus one more round.
David 8N482352
11-29-1999 19:09:51
 Re: Re: 8N lift problems........still in reply to ZANE, 11-28-1999 19:16:26
Zane, thanks for the list of "to-do's". I will check next time I get to town and pick up another lift cover gasket. I do not recall seeing any bent or damaged parts, but there may be some. I spoke to a fellow 8N owner today and he says the lift is not supposed to work with the small lever down. If I understood him correctly, he said this lever will go down when you hang a stump or bind your lift in some way. This then releases the pump presssure to prevent damage to the lift. Is this what this is for? Honestly, I have never used this lever in my 7 years of 8N ownership. I have tinkered with it though and never noticed any change until Sunday when I adjusted all of the linkages. Now, with the lever down, my lift will not do a thing.
Thanks for all of the good advice.
David in SC.
Nolan
11-30-1999 03:49:57
 Re: Re: Re: 8N lift problems........still in reply to David 8N482352, 11-29-1999 19:09:51
No, your friend isn't right. He's got the right idea; but an incomplete idea, and misapplied.
With the little lever in the up position, your lift control lever simply sets a position for the impliment. As in fully up, partially up, and on the ground. Quite usefull for bush hogs and lifts and such.
With the little lever in the horizontal position, you now have draft control. A fancy word meaning that the hitch is sensitive to the drag of a plow. The lift lever (quadrant) controls how much drag is allowed. Raise the lever, and less drag is allowed, lower the level, and more drag is allowed. The drag is controlled by the hitch raising the plow blades to reduce drag, and lowering them to increase drag. Very handy for plowing up inconsistent soil.
To get back to your friend, in the draft control, if you are plowing sand, and then hit some heavy clay soil, the hitch would lift the plow blades up until the drag was exactly the same as in the sand. To make up a set of numbers, lets say 10" deep in sand, and 3" deep in the clay. That's draft control. It's a constant drag, and changes plow depth to keep that drag constant. Your friend has taken this concept, and mangled it into thinking this means the plow would instantly lift itself out of the ground, or disconnect the pump upon hitting a rock (infinite drag). Not true. The system isn't that good. That's what spring loaded plow blades are for. And attentitive tractor operators.
EricG.NH
11-30-1999 08:02:03
 Re: Re: Re: Re: 8N lift problems........still in reply to Nolan, 11-30-1999 03:49:57
In addition to what Nolan said, a properly adjusted lift, operating in draft control mode(little lever horizontal), will raise and lower with the touch control lever as well. But that's all you get. All the way up or all the way down. In draft control mode, when the touch control lever is raised high enough, the lift should raise up and continue until it reaches the top. This is refered to as the "transport" mode or position for the implement.
Lower the touch control lever and at some point the lift will begin to drop and will continue until it reaches the bottom.
Somewhere between these two positions, the raise and lower positions on the touch control, is a neutral position. This is where the pump is neither intaking nor exhausting. In other words the lift stays put. It is however subject to leak down on not so perfect hydraulic systems. Automatic draft control mode will do nothing to correct for this drop. Automatic position control, on the other hand, will! It's not unusual for the draft control mode on the 8Ns to not work correctly, due to mis-adjusted, worn or broken parts. Most owners tend to use position control and some "fudge" the adjustments to allow it to continue to work on position control and sacrifice the correct operation of the draft control.
Hope this helps,
Eric
