Installing Weights
Joe
03-13-2000 19:26:02
Can anyone give me the details on installing 3-piece weights on an 8N?
RICK
03-13-2000 20:34:08
 Re: Installing Weights in reply to Joe, 03-13-2000 19:26:02
I used threaded rod to replace the original bolts when putting them on my 2000. Put a nut in the center of the rod, and another on the back side to hold the rim and disc as the bolts had. Put a segment on with the retainers leaving the nuts loose untill you get all the segments on. Then tighten everthing up. Drive it around a while and recheck periodically. Had them on two years without any problems. Due to the rim/disc positioning, mine are on the outside. Yours may not be, but it's easier and everybody can see you have them.
