Order Ford 8N Parts Online
8N Hydraulic Pump Gunk
Carmie
11-26-1999 21:35:10
I have drained all hydraulic fluid & have both
inspection covers off. How & what (solvent?) do I
use to get the "GUNK" flushed out of the bottom of
the pump/trans caseing? Thanks.
Sam (Mo.)
11-26-1999 21:46:18
 Re: 8N Hydraulic Pump Gunk in reply to Carmie, 11-26-1999 21:35:10
I cleaned mine out with K-1 kerosene. I don't know if there's something better or not, but the kerosene worked.
Carmie
11-27-1999 06:14:10
 Re: Re: 8N Hydraulic Pump Gunk in reply to Sam (Mo.), 11-26-1999 21:46:18
Sam from MI, When you used kerosene did you run your tractor
& the hydraulics to circulate and clean the inside
or did you just pour it in and let it soak??
Thanks
Sam (Mo.)
11-27-1999 22:36:59
 Re: Re: Re: 8N Hydraulic Pump Gunk in reply to Carmie, 11-27-1999 06:14:10
I just poured a couple of gallons in and let it soak. I ran the PTO and hoist a little with kerosene, but DIDN'T drive the tractor.
The same reservoir oils the transmission, and I bet driving around with kerosene in there would damage the gears.
