Order Ford 8N Parts Online
8n Won't keep running!
Dale
11-25-1999 17:28:26
I just put a rebuilt carb on my 8n,and it will NOT
keep running unless I have the choke knob pulled
all the way out.This is a 47 n with front distr.
Any help would be greatly appreciated,since I have
been working on this for 3 days now.
Max
11-26-1999 13:28:19
 Re: 8n Won't keep running! in reply to Dale, 11-25-1999 17:28:26
I have a similar problem that I posted earlier. I still haven't found the answer and it is very frustrating. Someone posted back that I may have an intake manifold leak. Does anyone know how you test for that?
Sam (Mo.)
11-25-1999 21:42:57
As most here know, I just had the same problem and posted several messages trying to find it.
In my case, something (I don't know what) was wrong with the rebuilt carb. If your tractor wants to be choked to run right, the fuel mix is running lean. That indicates an air leak somewhere between the carburetor and engine - or maybe like mine, the carburetor is just not delivering enough fuel for some reason.
Claus
11-25-1999 18:04:40
Sounds like you are pulling in air, check your gasket surfaces. If the mating surface to the manifold is ok, then I would take the carb back and get an other one..
Happy motoring
Claus
