2n Electrics
John 2n114296
11-24-1999 20:01:51
Happy holiday to all,
I am going to rewire because of a bad mish mash of solder, butt connectors, and wrong ga. wires. I have found that this recently purchased 2n has had battery hooked up for 6 volt negative ground. Do I have to flash the single wire generator if I go back to postive ground?
Thanks for all the good information I have found in this forum so far.
ZANE
11-25-1999 06:12:46
 Re: 2n Electrics in reply to John 2n114296, 11-24-1999 20:01:51
Yes, you should remove the wire from the cutout and momentarily strike it on the output terminal of the generator.
