2N hydraulic cylinder scored
Bruce
11-24-1999 11:15:35
I am R&R'ing the hydraulics in my 2N. The cylinder and piston has some big score marks in it. They are about 1 inch long and towards the middle of the cylinder. Can JB weld smooth them out? I really don't want to buy a cylinder. I also have a beef about folks not realizing that oil is cheap, parts expensive. If the fella that ignored the rusty looking oil had changed it every so often for $15.00, there would be no wear like this.
ZANE
11-24-1999 18:07:30
 Re: 2N hydraulic cylinder scored in reply to Bruce , 11-24-1999 11:15:35
You need to replace the N piston with the piston from an NAA with the neoprene ring with the leather backup ring. The scored places will not leak enough to matter if you will hone the cylinder before you install the new type piston. You probably could turn a gland on the old piston to receive the new type rings and have the same results if the piston is not scored too badly.
That theory about changing the oil in the N lift previnting the scoring of the cylinder is not exactly right.The real problem with the N hydraulic system is that there is no filter for the oil and that the oil is picked up too close to the bottom of the reservoir and the junk that comes into the system through the seals on the rocker shaft and the stuff that us shed off the unlubricated parts of the linkage and the pump and the pto etc just goes around and around in the system untill it finally finds a cozy spot to stay.
Changing the oil does not get rid of all the junk that is in the bottom of the lift. The only way to get rid of it is to remove the pump and pressure wash it or put it in a parts cleaner etc. The rubber rings will not score the clyinder walls like the steel ones will when a foriegn particle comes between the ring and the cylinder wall. It will begin to cut the rubber ring down and eventually it will leak just like the steel ring did but the cylinder walls will not be nearly as scored.
