Order Ford 8N Parts Online
8N 12 Volt Conversion
Jerry
03-12-2000 18:18:02
I have a problem...after installing a conversion kit the engine ran for a first use. After sitting a few weeks it would not start. I opened up the distributor cap to see the spark at the points and it appears the amount of fire between the points is exessive. Its firing downward into the distributor. I installed the resistor that came with the kit but wonder if it is working?
I tried hooking up an old 12 volt coil I had on hand and there was no change. If the resistor is defective shouldn't that keep any current at all from getting through?
Any help would be appreciated...
STUMP PULLER
03-13-2000 15:34:46
 Re: 8N 12 Volt Conversion in reply to Jerry, 03-12-2000 18:18:02
IF YOUR COIL DOES NOT REQUIRE A BALLAST RESISTOR, THE COIL RESISTANCE WILL BE ABOUT 3.3 OHMS. I WOULD CHECK YOUR CAPACITOR.
Claus
03-13-2000 04:01:13
If the resistor is properly hooked up i.e. in series with the ignition switch to the coil primary and if it were open, you would not get current to the coil. I take it, that you have a side mounted distributor since you can see the points when it is turning over and therefore do not have an external ballast resistor. You did not state if the coil is a 12 volt or 6 volt coil. Only the replacement coil is 12 according to your post. Some 12 volt coils need external dropping resistors and some do not. Some kits have 12 volt coils and some do not and supply the dropping resistor for utilizing a 6 volt coil. Your post did not give me much to go on... Happy Motoring
Claus
