Order Ford 9N Parts Online
9N CRACKED BLOCK-WHAT'S IT'S WORTH?
TX'n
11-18-1999 21:28:25
My first son and I have restored his great grandad's '44 2N and we took it for a spin on Halloween after many years of decay. I now know how tractor expenses correlate to household furnishings. A buddy who helped w/the project (and caught the bug) called tonight that the folks he work with (computers) have an old 9N with a cracked block and the wives are banishing it from the homestead for the holidays. Son #2 is to be born next Tuesday. Should I go ahead and bring this tractor home for the bonding experience? (We can all answer that one.) So, what is it worth with the bad block? I read all the posts, but please put things into perspective with the above dilemma. Thanks for the help as always-I need to make an offer on Friday.
wht/dmd
11-22-1999 14:55:26
 Re: 9N CRACKED BLOCK-WHAT'S IT'S WORTH? in reply to TX'n, 11-18-1999 21:28:25
about 3cents a pound
Ken
11-21-1999 19:02:49
If you are going to paint , polish , wax and worship it then you don't want it but if you need a cheap tractor and the cracked block is repairable (J B weld , braze , or nickel rod with an arc welder are options ) check out the price of a MTD riding lawn mower at Walmart around 800.00 ask yourself if it's worth more than that? You probably need more info on the "crack" if it has been frozen hard with straight water in it there is no repair cause the block will be broken up inside and out but with some small cracks you might get by with nothing but a dose of stop leak.Ask yourself why do you want it , if you want to teach the boys about internal combustion engines and you are up to it mechanically a junk yard block and lots of garage time might be just the ticket. The serial #s won't match so if you are planning on treating it as a shrine to worship that would be points deducted. If you don't save this ford who will ? Is it fate that you have been given this chance at the time of the birth of your son ? Is it a sign from God ? If I thought it was repairable without a new block depending on tires and implements I'd consider 1000.00 ( 200.00 more than a fine MTD lawn mower and much more useful )
