Bad years?
MJ
11-17-1999 14:50:28
I was just wondering, are there certain years when the 9N's thru 8N's seemed to be problem childs. Sometimes particular types of cars will have years when they seem to give owners problems. Did some N-years have problems, are were they all basically the same? Are there any particular years that stand out as being more desirable than others and why? Thanks.
Hey busdriver
11-17-1999 22:45:40
 Re: Bad years? in reply to MJ, 11-17-1999 14:50:28
By no means am I an expert on this subject or any other subject relating to tractors, but the only thing I can think of is being extremely light in the front end and lack of live hydraulics, and with the 9N and 2N is position control, but have never heard of anyone ever complain of durability or poor design. Just my observation.
Stan
Sam (Mo.)
11-17-1999 21:10:52
Since I use my N's a lot as working tractors I'm glad both of mine are 1952 8N's. Position control, 4 forward gears, side distributor, better axle seals, and many other little things - I think they made lots of improvements between '39 and '52.
I like all the N's, though, and if I found a good 9N, 2N, or front-distributor 8N I'm sure I would want it. I'm even interested in getting a Golden Jubilee some day, I don't know much about them, but I like the way they look.
d.o.n.
11-17-1999 17:41:29
Yes Ford had some bad times. Rear end of N's comes to mind. SOS was major problem on later models (not N's). Ford, to its credit, fixed them and moved on. D.O.N.
A BAD N. Is there any such thing.
11-17-1999 17:11:29
A BAD "N". Is there any such thing.
Norm
11-17-1999 16:37:26
They are all bad years---As my old Pappy used to say, an old tractor is like an old mistress.They both require a whole lot of maintenance and don't give a whole lot of satisfaction---heh heh
bg
11-17-1999 15:34:23
IMO, the Ford people kept trying things and refining the design as they went. I think they found the front-mount distributor and the early axle seals to be of questionable design, otherwise they wouldn't have changed them. It difficult to remember sometimes that in 1939 the automotive engineering field was still rather primitive. There have been quantum leaps in engineering and technology in the past 50 years and it's interesting to watch the evolution of the Ford line. On the other hand, the engineering of the Ford was sound and enduring, somewhat avant garde for the time. Interesting to note that the basic Ferguson/Ford concept is still around. As far as good years and bad years, depends on what you like. I'm glad I have a 52 8N, as it was as good as they made up that point, although it's not without its critics for such things as gear ratios.
Jim(UT)
11-17-1999 15:22:57
I'll take a stab at this even tho I don't own an N. Bad year? Don't think any year is any worse or better than any other as far as frequency of breakdown is concerned. There were various enhancements and improvements that occurred thru the years. If the latest and greatest is what you're after get a later one. Desireability? Depends on what purpose you have in mind. Going to use it? Get an 8N with position control or plan on buying Zane's invention to give a 9n/2n position control. Just want a collector item to restore/show? Beat the bushes for a 1939 9N with aluminum grille (good luck). There was one year during WW2 when 2N's were equipped with a magneto and hand crank start (saving copper for the war effort). Good luck.
