Order Ford 8N Parts Online
1948 8N Hydraulic pump / oil inside inspection plate
Todd in Northce
11-16-1999 14:40:56
I own a 1948 8N. I have previously used the hitch and hydraulics before with sucess. I just purchased a new brush hog and also used it successfully one time.
Now it suddenly will not raise the implement.. I suspect the hydraulic pump needs replacement or overhaul.
I removed the inspection plate on the side of the transmission as directed... and I cannot find the "control valve" inside the chamber.
Q# 1 can anyone supply direction once inside the plate to locate it? & does it matter which side you open it up from?
The manual also indicates that the oil should not be moving inside the chamber with the engine running. Mine is moving / agitating and SHOOTING etc...
Q #2 Does this mean that the gasket in the hydraulic pump is leaking by and/or do I need to just overhaul the pump?
llamas
11-16-1999 14:50:45
 Re: 1948 8N Hydraulic pump / oil inside inspection plate in reply to Todd in Northcentral Pa, 11-16-1999 14:40:56
You can't see the control valves because they are submerged in the oil.
You may see rythmic movement in the surface of the oil, caused by the pump yokes moving back and forth. But if oil is squirting from the surface, you have a high pressure leak somewhere, which is why the hitch don't work.
Post back the exact location that you see oil squirting from and we'll cover the most likely causes. It may help to drain about 2 gallons of the oil, so the pump and check/relief valve assembly are exposed. The hydraulics will still work - watch for high-pressure oil and don't get it on you, this can do you big harm.
llater,
llamas
Todd
11-16-1999 16:13:34
 Re: Re: 1948 8N Hydraulic pump / oil inside inspection plate in reply to llamas, 11-16-1999 14:50:45
Draining the oil is a great idea that I had not thought of. It is definately "spraying" but from under the surface. I opened the plate on the side of the clutch... and again, without draining the oil - it seems to be coming from the gasket between the valve chamber and the pump base on the right side of the pump. I think the gasket is pushed out.
It may take a couple of days to drain it and be sure - it's 20 degrees here now with a stiff wind.
As long as I might have to have it off...
My only local supply has no overhaul kits.. They will sell a rebuilt pump for $549.99 !!! Which is way to much. Can you suggest any suppliers for the kit?
