Order Ford 9N Parts Online
9N Cam Gear (con't)
kevmc
03-11-2000 07:28:29
Just an update..I've pulled the head, valves and cam out! Fiber gear was missing 9-10 teeth. Local Ford dealer says he can get a cast gear and press it on for me. Parts (gear, gaskets and tune-up kit on order! Toughest part lools to be compressing the valve springs to reinstall, any hints? Will be in touch! kevmc
bg
03-11-2000 07:46:09
 Re: 9N Cam Gear (con't) in reply to kevmc, 03-11-2000 07:28:29
By all means use the cast gear. The valve springs aren't tough to compress if you have the right tool. get a valve spring compressor for a flathead, not OHV engine. I'd be inclined to replace all the valve springs since you already have them out. Old ones can fatigue and lose their "spring".
