Order Ford 8N Parts Online
8N slipping out of gear
JB
11-10-1999 05:53:34
My late model 8N slips out of gear when going down hill. If I hold the shift lever in gear when going down hill it stays in gear. What is the most likely cause of this problem and how much will it cost to fix. Thanks in advance for any help.
JB
Jim
11-11-1999 03:27:52
 Re: 8N slipping out of gear in reply to JB, 11-10-1999 05:53:34
You might as well plan on a tear down. That trouble is usually because the bearing in your input shaft is out and the surface in there is worn bad. This bearing has a tremendous amount of strain on it and is the one bearing that suffers most when your oil level is low or has water in it. It allows the shaft that has all the sliding gears on it to move up which causes the sliding gears to move out of mesh. Ususal cure is a new input shaft and bearing, used ones are very hard to find that are good.
ZANE
11-10-1999 19:23:23
There is something worn in the transmission that is causing the gear to become out of alignment with another gear and this causes it to walk itself out of gear.Usually it is worn bearings or in some cases if the gear in question turns on the OD of another gear or shaft the clearance can become too great and cause it to wobble slightly and that is all it takes to make on jump out of gear.
The 5 speed is notorious for jumping out of 3rd gear on the later models.
The only thing that will cure it is to go into the transmission and replace everthing that has too much clearance in it.
It is possible that the pilot bearing in the flywheel can cause some problems with jumping out of gear if it is really bad. YOu should check it out while the transmission is out of the tractor.
Peter Taylor
11-10-1999 17:15:54
Mine is an 800, but it too pops out of gear (5-speed). I know this is an 8N site, but would appreciate any comments from a knowledgable person, as I asked our local repair man (John Deere) and he said he wouldn't even know who to ask. Thanks, Peter
