43 2N front seal
John
11-06-1999 18:47:11
How tough is it to replace the front crankshaft seal?
ZANE
11-07-1999 04:21:46
 Re: 43 2N front seal in reply to John, 11-06-1999 18:47:11
The pan must be pulled and this usually involves pulling the hood and front axle assembly etc.
The bottom seal is easy to replace by just pullin out the old one and replacing it with a new one.The top one is another story.The best thing to do is to take a punch and pack the old top seal up on both sides as far as you can with out striking the crankshaft and scoring it. Then obtain some cotton roping and pack it into the void that you made with the flat ended punch in the top seal. The TO Ferguson main seals are cotton roping if you cannot find suitable cotton roping elsewhere. Cotton roping is not rope, it is what is first formed in the process of making yarn from cotton fibre. I think that you could use cotton balls if nothing else can be found to use.
This sounds like a poor way to repair a leaking seal I know but I can assure you that it is a proven process and the only alternative is to pull the engine and pull the crankshaft to replace the top seal.
The only crank seal that the TO Fergusons have is cotton roping that is packed into the groove after the crank shaft is installed. I have a TO Ferguson and installed the rear seal just this way over 35 years ago and it is still there.
John
11-07-1999 08:20:31
 Re: Re: 43 2N front seal in reply to ZANE, 11-07-1999 04:21:46
Thanks for the info Zane. I have used long fibered cotton caulking on old wooden boat plank seams in the past.It comes in bundles and kind of looks like what yarns would be made of before its twisted together.Think this would be o.k.? Are there gaskets between the oil pan and the engine block surface?
