Order Ford 8N Parts Online
Loading Tires on an 8N
john compton
11-06-1999 12:31:57
Hi,
I just purchased a '50 8N with a 6 foot blade and a front end loader. I need to load the tires for pulling snow around and when I use the bucket. I don't want to use chloride (unless I have to)because of the wheels rusting. What should I use and whats the procedure for loading the tires? I'd appreciate any help.
ike
11-06-1999 21:54:19
 Re: Loading Tires on an 8N in reply to john compton, 11-06-1999 12:31:57
i have the calcium chloride in mine... and yes it will eat them up.
al's suggestion for the antifreeze is good.
one thing i would not recommend, based on a friend's experience is tyr fill or similar. i think it is a liquid that hardens and basically turns your tires into solid tires. while good for flats/weight, the guy i know was carrying a heavy load in his loader, drove up onto a concrete driveway, and trashed a rim and axle due to the tires no longer cushioning the impact.
good luck
AL@NC
11-06-1999 12:59:05
You can use water and antifreeze. You can buy an adapter to go from a garden hose to the the valve stem and a drill operated pump to fill the tires with. Remove the valve stem to fill. Like pouring sand out of a boot....
