3pt. studders
terry in MI
11-05-1999 19:29:44
I have a 9N and When I lower my 3 pt whether it be my brush hog or blade and I try to hold it slightly above the ground I get a slipping motion. Is my hydraulic pump going out? (Oil is fresh and up to level.) It seems to raise fine and lower fine, but it just won't stay steady in between. Is is better to replace now or wait until it gets worse? What can I expect to encounter when I replace the pump. (IE. time??) I am a pretty good tinkerer and usually figure things out, but should I just let my dealer do it?
bg
11-05-1999 22:19:06
 Re: 3pt. studders in reply to terry in MI, 11-05-1999 19:29:44
That's the nature of the beast without position control. You have up and down. In betwen it "hunts" for pressure equalization. Call Zane Sherman and order a ZANE THANG.It should cure that problem. If the system is really in need of overhaul, you can do it. Get an FO-4 manual and make adjustments before you do anything more.
