Order Ford 8N Parts Online
8N oil pan removal
Jim Hannibal
03-06-2000 21:25:27
I don't have a service manual yet, but I'm going to get one. I'm trying to remove the oil pan from my 1947 8N, and it isn't coming off. This is what I have removed so far:
2, 1/4" pan to front cover bolts
6, large front axle to pan nuts and bolts
4, large, lower bell-housing to pan bolts
and all of the side pan bolts.
The front axle is off, and the pan still won't move!
Is there some small bolts behind the bell-housing?
Do I have to split the block from the Bell-housing?
Please help. Thank you in advance.
Stever(oh)
03-07-2000 09:02:41
 Re: 8N oil pan removal in reply to Jim Hannibal, 03-06-2000 21:25:27
Be careful of your oil pump pickup tube. As I remember, it hangs down there pretty far. If you drop the pan straight down, no problem.
Jim Hannibal (CA)
03-07-2000 20:09:14
 Re: Re: 8N oil pan removal in reply to Stever(oh), 03-07-2000 09:02:41
Thanks for the information regarding the removal of my 8N's oil pan. As you both said, "It sould come straight down", and you were right.
I had to beat and pry on the edge pretty hard, but it gave way after a while.
I was able to discover why I, could see soo much of the rings on the number 3 piston, the sleave was in little chunks in the bottom of the pan!
What I thought was the cylinder wall was actually the side where the sleave should have had a press fit.
I guess that I will need to pull the engine after all as to bore and sleave with a .090 sleave set, at least I hope that may be done.
Thanks again for your help.
Bill OH
03-07-2000 04:38:47
You got the 2 front ones out right? I didn't do this and ended up stripping the bolts (luckily) not what they screwed into. There are no other bolts. You should be able to pry the pan off now (carefully), probably some old "stickum" has it glued in. Be sure to put a floor jack under it because it is heavy and you don't want it dropping onto the floor (or your foot or hand or head!). I was able to get mine off without removing the front axle, just had to loosen the control arms to get the pan back on.
Mario
02-03-2002 12:16:05
 Re: Re: 8N oil pan removal in reply to Bill OH, 03-07-2000 04:38:47
You had removed an oil pan from a 8N without taking apart the front axle. I would like to do the same. Can you give me some more info?
The oil pan seems to make the link between all the powertrain and the front axle. How can I support the engine while the oil pan is off?
Jim Hannibal (CA)
03-07-2000 20:16:11
Thanks for the information Bill, you were correct!
Now that the pan is off, I have found bits of the sleave (the entire sleave) at the bottom of the pan.
