2N engine noise
DAve 2N
03-06-2000 10:24:56
Guys -need some advice
My 2N was making a noise, like lifters? Took off manifold to check clearances (they were OK) but manifold was cracked so I replaced it. Noise still there and traced to area of governor. Was told that the governor case can wear from the inside. Any advice before I rare into the governor?
Geoff in MN
03-06-2000 20:30:04
 Re: 2N engine noise in reply to DAve 2N, 03-06-2000 10:24:56
Do you have an external oil line going to your governor? There was a factory approved retrofit after it was determined that splash lubrication from the housing was inadequate.
llamas
03-06-2000 12:14:17
If definitely isolated to the governor, then the noise is the sound of the governor flyballs trying to escape from the housing. Your governor needs a complete rebuild and adjustment. Figure $80 for the "complete" rebuild kit plus a couple of hours work to do the job. You will need a bolster press to remove and replace the driven gear.
HTH,
llater,
llamas
