Order Ford 8N Parts Online
8N 3pt lift
Ken Centers
03-06-2000 08:33:11
I recently purchased an 8N that has been completly restored. The 3 point lift arms seem to be out adjustment. I have looked at other 8N tractors and the lift arms come up nearly to the back of the seat. Mine will not come up near the seat and they drop much lower than normal. Is it possible they were reinstalled improperly during reassembly? I removed the arms from the shaft but they are keyed for only one mount position. Has anyone seen this problem before? Thank you.
ZANE
03-06-2000 18:59:41
 Re: 8N 3pt lift in reply to Ken Centers, 03-06-2000 08:33:11
It is possible that the rocker arm inside the lift that the ram rod pushes against is bent or broken. I have seen them be broken and rewelded back in the wrong position and this will cause the condition you are describing.
I have a jig and pamplet that you can use to correctly adjust the 8N lif if that is the problem.
Mark 8N126975
03-06-2000 13:53:04
It is relatively easy to take the arms off.They are on splined shafts. It's possible that they merely need to be repositioned on the spline.If there is a slot or "keyway" on the spline allowing only one way to put it on,see if they need to be switched or flipflopped.
