If you don't want tin (steel siding) than you want a standard garage. Go to your local lumberyard. They sell garages and pole barns as kits and can also recommend a contractor if you don't want to do the work. A couple of comments. If you do build a pole barn, and I really see nothing wrong with steel siding, opt for a wood deck and shingled roof. They don't sweat. Unless you are in a dry climate without varmints-rats, woodchucks, etc. and your budget can afford it - put in a concrete floor. I have a gravel floor and about 1/4 of the time it is mucky because of a high water table. Have a neighbor that has horses and along with horses and grain are rats, and have had an occaisional rat burrow around the gravel under mower decks and the like. A floor slab on proper footings and rat walls is useful. Also, depending on where you live, check the local building authority. Our township will no longer allow gravel floors in anything accept an agriculturally zoned barn and even then they squawk. Finally, opt for 10 or 12 foot sidewalls. 8 are too short to work on anything. Build the barn as big as you can afford. Mine was 30 X 40 and with a son with vehicles I had to add an 10X40 piece on. IMHO JerryU
