Another Law
Murphy
03-05-2000 07:47:32
When working on a vehicle and a tool or part is dropped, it will roll or bounce under the vehicle to the exact geographical center.
John Regan
03-08-2000 21:58:33
 Re: Another Law in reply to Murphy, 03-05-2000 07:47:32
Shortly after Murphy's entire laws were published there was a new theory proposed by O'Toole. It became known as O'Toole's Law and in short it simply stated that Murphy was an optimist.
bobeque
03-05-2000 17:10:45
If you take your "N" apart and put it back together enough times, you will eventually have two of them.
The corollary is:
03-05-2000 17:01:15
All small parts, when working on that same vehicle, will lodge in the MOST inaccessible place on the vehicle.
The second corollary is;
If the inaccessible place is viewable, then the part is more likely to lodge in a location slightly more accessible BUT impossible to view from any angle.
Larry 8N75381
Vic
03-05-2000 07:54:08
You forgot to mention open floor drain that's ALSO located exact geographic center...
hey busdriver
03-06-2000 01:47:44
 Re: Re: Another Law in reply to Vic, 03-05-2000 07:54:08
If you don't have a drian, start looking for the part about 6 to 8 feet awaw from where you think it might have fallen, if you are lucky it will be under neath a bench or in a dark spot aboout that distance away.
Good luck Stan
Tyler(MD)
03-05-2000 11:02:01
You failed to mention that the part or tool drops on foot first crushing toes then moves to the to the exact geographic center... :-)
Tyman
